Cannot find the Heightfield Mask by Shadow node inside of Houdini
   2851   8   2
Hello!
I was excited to install 17.5 and try out the Heightfield Mask by Shadow node (http://www.sidefx.com/docs/houdini/nodes/sop/heightfield_maskbyshadow.html). The problem is that I cannot find it in Houdini. And the same thing goes for my colleagues. Does anyone know what's going on?
Thank you!
No ideas?
I'm still curious to see why this is!
the answer is at the link you posted:
This node type is hidden. It is no longer supported.
however I don't know the reasons behind as it seems useful
you can still unhide it at your own risk
opunhide Sop heightfield_maskbyshadow
Edited by tamte - July 12, 2019 05:09:12
Thank you, Tomas! It worked like a charm. I don't know how I missed that… Maybe because I was expecting it to be a brand new node. And yes, it's a very useful node!
/Erik
Actually, I spoke too soon.
I get this error at times when changing direction and angle:
OpenCL Exception: clFinish (-36)
OpenCL Context error: CL_OUT_OF_RESOURCES error executing CL_COMMAND_READ_BUFFER on GeForce GTX 1080 (Device 0).
Any ideas on how to fix this? The work around now is restarting Houdini. Thanks!
I made a wrangle node that makes a mask from the shadow of a directional light or a point light.
It is not very optimized but it can be optimized and converted to openCL for instance to make it a lot more faster.
HeightfieldShadowMask.hip (215.1 KB)
Thanks, Arjan! It works really well!
ErikHallberg
Hej Erik Sounds like gpu is out of memory? Tried reducing the heightfield size?
B.Henriksson, DICE
