So not sure if this is a bug or a limitation. I'm just trying to use $CEX,$CEY,$CEZ to center the translate pivot prior to doing a transform. This works perfectly fine with a transform SOP, but a Copy and Transform SOP does not.
Is this expected?
H17.5.229 - Linux.
Thanks,
Ollie
$CEX Not working on Copy SOP
5034 3 0-
- revilo3d
- 33 posts
- jsmack
- 8178 posts
Yeah, that won't work. Try the centroid() expression:
http://www.sidefx.com/docs/houdini/expressions/centroid.html [www.sidefx.com]
- revilo3d
- 33 posts
- tamte
- 9416 posts
revilo3d
Can you explain why that does not work? I'm following a tutorial where is certainly used to.
there is no more Copy SOP in Houdini, the old Copy SOP (probably what you see in tutorial) was renamed to Copy Stamp SOP and still should work as in tutorial
the new copy operators are named Copy To Points SOP and Copy And Transform SOP and those don't allow local variables as local variables are being phased out due to performance and other reasons
Edited by tamte - May 20, 2019 22:31:56
