issue when writing geometry
   3399   3   1
This is a very simple hda, but fails on writing geometry. It seems that as soon as i add `@pdg_index` to the filename, it can not cook anymore.
Any ideas on what I could be doing wrong ?
Edited by heimlich - June 17, 2019 11:27:11
pdg_issue.mp4 (3.3 MB)
Oliver Hotz
#creator of ODShelfTools for Houdini: https://origamidigital.com/cart/index.php?route=product/category&path=59_63 [origamidigital.com]
This looks to be an issue within Houdini itself. Your HDA appears to be triggering some functionality within Houdini that is crashing. This is probably not to do with PDG itself, but rather some other bits of Houdini functionality. If you could please attach the HDA and the data involved, we could track it a bit further to see exactly what is crashing.
- Ken Xu
kenxu
ahh. great.. thanks for letting me know.. I'll file a proper report with everything attached !.
Oliver Hotz
I just packaged everything up, and before sending, i tested it again. and this time, everything worked fine. (i had put everything into the $HIP folder.. the images, the hda and output dir also.
I wonder if it has something to do with the hda being in the documents folder normally, versus in the $hip folder that i created for sending everything. I will check this some more as I dont want to waste your time.
Oliver Hotz
