How to use the attribute:hemax_material and hemax_matid,
When I select the object in the scene with hda,
The materail just gone..
How to get matierail in hda
5683 1 0-
- 3W
- 7 posts
- brooke_sidefx
- 396 posts
hemax_material should be a detial attribute that uses the following syntax for specifying a material:
For example if you had a material library with the name RockMaterials.mat and you wanted to use a material called RockInterior, the attribute should look like this:
The hemax_matid should be a primitive attribute that specifies the material ID for each face of the mesh.
<PathToMatFile>:<MaterialName>
C:\materials\RockMaterials.mat:RockInterior
