Visualization Behind "Fit Range" VOP Node !!!
7061 6 1-
- papon
- 34 posts
- CYTE
- 802 posts
- papon
- 34 posts
- tamte
- 9374 posts
paponit's just math so while I'm not sure what exact math is behind houdini fit function it will be along these lines
can you elaborate the mechanics behind it ? then it might be helpful .
https://rosettacode.org/wiki/Map_range [rosettacode.org]
just note that fit() function (Fit Range VOP) returns clamped results while efit() function (Fit Range Unclamped VOP) will not clamp the results
Edited by tamte - July 22, 2019 11:09:21
- Renji_kan
- 23 posts
CYTE
Hey papon,
"fit range" takes values from one range for example from -1 to +10 and "fits" them into a new range for example 0 to 1.
So a value that used to be -1 is 0 after the operation.
Please tell me, where and how to look at the description of the FitRange nodes?
Here is a description on the site: https://www.sidefx.com/docs/houdini/nodes/vop/fit.html [www.sidefx.com]
But, I do not see a description of the Input parameters, what types they are and what the fit range node returns.
Is there such a description? or should I guess myself what the houdini developers did there?
Sidefx
- vusta
- 555 posts
here's a visualisation, I used VEX fit in a wrangle but it should be the same as a VOP (if you view the code in the VOP you'd see it calls vop_fit(), how you drill down further I don't know, you'd probably reach unreadable machine code)
Anyway, visually it remaps your min/max to newmin/newmax...
Adjust MinX, MaxX, NewMinX, NewMaxX and observe...try NewMinX = 4 and NewMaxX = -1 and you'll see it crosses over itself.
So here's my reverse engineering
mathematically: (it's just ratio)
x / (MaxX - MinX) = new x /(NewMaxX - NewMinX)
therefore, the fit is getting the new x value by:
new x = x * (NewMaxX - NewMinX) / (MaxX - MinX)
just my guess...don't sue me if your computer explodes.
ps: I'm quite confident on my logic as I had to write my own remap in MCG (hush....3dsMax!) and that's what I used..it worked fine I think.
Edited by vusta - June 13, 2021 18:13:55
- vusta
- 555 posts
