What I'm looking for is similar to Nuke's O-flow tool (where a 2d grid of motion vectors are generated for an image sequence, based on image information).
I wonder if similar could be possible using existing Houdini tools (microsolvers?) for volumes? Say, I have a sequence of 3d volumes (scalar/density), and I'd like to generate a motion vector volume for them, by analyzing the difference between the volume on the current and the next frame.
I hope I'm making sense here
thanks
iosman
motion detection- microsolver(?)?
1661 2 0-
- iosman123
- 2 posts
- jsmack
- 8177 posts
I think this is the node you're looking for, but I'm not sure if it exists as a microsolver. If you need it in a solver, it can be put into a sop solver.
https://www.sidefx.com/docs/houdini/nodes/sop/volumeopticalflow.html [www.sidefx.com]
- animatrix_
- 5103 posts
You don't need a microsolver for this but if you need it, you can just invoke Volume Optical Flow from a SOP Solver DOP inside a DOP network.
