OSX NSLocalizedFailureReason=Font registration was unsuccessful
   2370   1   0
I'm getting this giant print out every time I run Houdini 17.0/17.5.
Any idea how to fix it / suppress it? Thanks.
2019-07-21 17:31:44.181 hindie[18941:1059811] Unable to register font: Error Domain=com.apple.CoreText.CTFontManagerErrorDomain Code=105 "The file has already been registered in the specified scope." UserInfo={NSLocalizedDescription=The file has already been registered in the specified scope., CTFontManagerErrorFontURLs=(
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Lato-HeavyItalic.ttf"
), NSLocalizedFailureReason=Font registration was unsuccessful.}
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Lato-Italic.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Times-Roman.pfa"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Courier-Bold.pfa"
2019-07-21 17:31:44.182 hindie[18941:1059811] Unable to register font: Error Domain=com.apple.CoreText.CTFontManagerErrorDomain Code=105 "The file has already been registered in the specified scope." UserInfo={NSLocalizedDescription=The file has already been registered in the specified scope., CTFontManagerErrorFontURLs=(
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/SourceSansPro-ExtraLightIt.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Lato-LightItalic.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Utopia-Bold.pfa"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Helvetica-BoldOblique.pfa"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/SourceCodePro-Semibold.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Lato-Thin.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/WenQuanYiZenHei.ttf"
2019-07-21 17:31:44.183 hindie[18941:1059811] Unable to register font: Error Domain=com.apple.CoreText.CTFontManagerErrorDomain Code=105 "The file has already been registered in the specified scope." UserInfo={NSLocalizedDescription=The file has already been registered in the specified scope., CTFontManagerErrorFontURLs=(
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Lato-Bold.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Lato-Black.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Helvetica-Oblique.pfa"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Symbol.pfa"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Vegur-Bold.otf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/SourceSansPro-BlackIt.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/SourceSansPro-Regular.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/DejaVuSerif-BoldItalic.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Times-Bold.pfa"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/SourceSansPro-BoldIt.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Lato-SemiboldItalic.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/SourceSansPro-It.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Helvetica.pfa"
2019-07-21 17:31:44.184 hindie[18941:1059811] Unable to register font: Error Domain=com.apple.CoreText.CTFontManagerErrorDomain Code=105 "The file has already been registered in the specified scope." UserInfo={NSLocalizedDescription=The file has already been registered in the specified scope., CTFontManagerErrorFontURLs=(
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Lato-HairlineItalic.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/DejaVuSans-BoldOblique.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Utopia-Italic.pfa"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/SourceSansPro-Bold.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/DejaVuSans.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Lato-Regular.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/DejaVuSansMono-BoldOblique.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/DejaVuSerif.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/SourceCodePro-Light.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Lato-Hairline.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/SourceSansPro-Light.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/SourceSansPro-SemiboldIt.ttf"
2019-07-21 17:31:44.185 hindie[18941:1059811] Unable to register font: Error Domain=com.apple.CoreText.CTFontManagerErrorDomain Code=105 "The file has already been registered in the specified scope." UserInfo={NSLocalizedDescription=The file has already been registered in the specified scope., CTFontManagerErrorFontURLs=(
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Lato-BlackItalic.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/SourceSansPro-LightIt.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Lato-Semibold.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/WenQuanYiZenHeiMono.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/SourceCodePro-Black.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Lato-MediumItalic.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/SourceSansPro-Black.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Times-Italic.pfa"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/SourceCodePro-ExtraLight.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Utopia-BoldItalic.pfa"
2019-07-21 17:31:44.186 hindie[18941:1059811] Unable to register font: Error Domain=com.apple.CoreText.CTFontManagerErrorDomain Code=105 "The file has already been registered in the specified scope." UserInfo={NSLocalizedDescription=The file has already been registered in the specified scope., CTFontManagerErrorFontURLs=(
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/SourceCodePro-Regular.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Utopia-Regular.pfa"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/DejaVuSansMono.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/DejaVuSans-Bold.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Courier-Oblique.pfa"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Lato-Heavy.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Vegur-Light.otf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Courier-BoldOblique.pfa"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Helvetica-Bold.pfa"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/SourceSansPro-ExtraLight.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/DejaVuSansMono-Bold.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Lato-BoldItalic.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Lato-Light.ttf"
2019-07-21 17:31:44.187 hindie[18941:1059811] Unable to register font: Error Domain=com.apple.CoreText.CTFontManagerErrorDomain Code=105 "The file has already been registered in the specified scope." UserInfo={NSLocalizedDescription=The file has already been registered in the specified scope., CTFontManagerErrorFontURLs=(
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Lato-Medium.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Lato-ThinItalic.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/SourceSansPro-Semibold.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/DejaVuSansMono-Oblique.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Times-BoldItalic.pfa"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/DejaVuSans-ExtraLight.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/DejaVuSerif-Bold.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Courier.pfa"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/DejaVuSerif-Italic.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/SourceCodePro-Bold.ttf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/Vegur-Regular.otf"
"file:///Applications/Houdini/Houdini17.5.258/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/fonts/DejaVuSans-Oblique.ttf"
Edited by jbartolozzi - July 21, 2019 20:34:06
Here's how I fixed this problem thanks to SideFX support.
You can also try resetting your Houdini to it's defaults by deleting (or renaming) your $HOME/houdini17.5 directory.
When you relaunch Houdini this directory will be regenerated, with all your Houdini settings at default.
On MacOSX:
To reset preferences in $HOME/houdini17.5: On Mac OSX, the prefs directory is located in $HOME/Library/Preferences/houdini/17.5. Delete the 17.5 directory, (or temporarily move it aside, which is safer), and see if that fixes the error. If you do have a $HOME/houdini17.5 directory, (sometimes Houdini creates this on OSX), then delete that as well.
