1.plz someone enlighten me about this node cuz there is no info. for me to absorb from docs,it seems this node is bit technical in nature.
2.point me to resources for this kind of stuffs.
what the heck is "IsoSurface" SOP Node ??
3949 2 2-
- papon
- 34 posts
- malbrecht
- 806 posts
Trying to translate your text, I assume you haven't tried the search function on the docs, which points to https://www.sidefx.com/docs/houdini/nodes/sop/iso.html [www.sidefx.com]
Question for you: Do you know what “Iso Surfaces” are? If not, your second point would seem to make at least some sense, else a “resource” for “this kind of stuff” would probably be a volume …? Or a 3d grid?
As for “nodes being technical in nature”: Most Houdini nodes tend to be.
Marc
Marc
Good bye.
Good bye.
- jsmack
- 8177 posts
The isosurface sop converts the surface of an implicit function into polygons using the marching cubes algorithm.
for more background info:
https://en.wikipedia.org/wiki/Isosurface [en.wikipedia.org]
https://en.wikipedia.org/wiki/Implicit_surface [en.wikipedia.org]
