(Solved) HF Scatter issue
   4699   3   0
Hello, i started again from scratch and i have very good results, soon i could place villages, roads, trees, rocks, etc only with houdini…
Well, i have now a small issue, when i use hf_scatter.
Following this tutorial video : https://vimeo.com/296439268 [vimeo.com]
Image 01 : In this image no problem
Image 02 : If i use terrace or erosion, i got this error
EDIT : Same error after the erosion node
Workaround: Isolate Height Layer, scatter object, then merge with eroded terrain back, will give 2 terrains be carefull, dunno how to delete the other one
Edited by samuelbrunner - July 30, 2019 06:26:01
Samuel_terrain_for_unity.hdalc (78.7 KB)
HF_Scatter node is poorly written, you can dive in that node and check which one is reporting this error.
Will do
Solved, was out of ram
