Command Chain problems due to Python Script Node
   2557   2   1
I have the problem that as soon as there is any kind of python node upstream of a command chain, it messes up the cooking process.
This happens even when the python node is not doing anything.
Did anyone have this issue before? (Tried on 17.5.327 and 17.5.350)
Cheers!
Philipp B. | Houdini TD @ Axis Studios
It's probably because the Python script node's workitem generation is actually dynamic by default, when it's on automatic (we have a bug to fix this). Once a node is dynamic, the rest of the graph becomes dynamic, which may be what's messing things up here. Try explicitly setting the workitem generation to “static”.
- Ken Xu
Thanks Ken, that did the trick!
But let's say I would want that chain to be dynamic, what would be the solution in that case?
