Getting work item output within Maya server TOP node
   1832   1   0
( I asked the same questions on tech-artists.org but thought i might have more luck here)
https://discourse.techart.online/t/getting-work-item-output-within-maya-server-top-node/11657
So I’m trying to send an output to the next node within the maya server, but the output gets sent to the maya start node instead of the node itself, so i can't send it to the next node.
some screenshots: https://imgur.com/a/PInwaW0 [imgur.com]
Hi there.
This is expected behaviour because you are overriding the supplied reportResultData with the implementation in pdgcmd. Remove the import, and it should work as expected.
