Struggling with bbox expression
   7191   4   0
I am trying to set the box in my scene to always be the same position as the top of the columns , on transform 2 I have this expression in the Translate Y attribute `bbox(“../supports”, D_YMAX)` but I am getting the error
Unable to evaluate expression (
File “”, line 1, in
NameError: name ‘bbox’ is not defined
(/obj/road_asset/transform2/ty)).
Did you happen to copy and paste the expression from this forum?
Manually change the quotes by using your keyboard for those quotes.
Don't use those back ticks and have node set to HScript.
Edited by BabaJ - Sept. 20, 2019 11:17:16
hello,
as babaj said you don't need the backticks `` wrapping your expression for non-string parameters.
also check if by any chance you have set the language expression for that param to python, instead of hscript
Edited by Andr - Sept. 20, 2019 13:17:03
So I've changed the language expresion to hscript but it's still not working
Okay I deleted the node and added it again, everything is working now thanks guys!
