Hi Guys!
First time posting here, I have a quick question: I made a voronoi fracture HDA for 3dsmax and I was wondering if there was a way to have the pieces become separate objects rather than elements of the same object.
Any thoughts on this are welcomed!
Outputting Individual objects out of a Fracture HDA
6920 1 0-
- Mahiky
- 1 posts
- brooke_sidefx
- 396 posts
Hi – if I understand correctly, you want a node for every piece of the fractured object?
This is possible using packed primitives. After your Voronoi fracture node, you will want to use a Pack node with the “Name Attribute” parameter enabled and the “Create Packed Fragments” parameter disabled.
Edited by brooke_sidefx - Nov. 8, 2019 14:35:59
