Hscript to map frame or time dependent value
   1264   4   1
I need to define a Hscript value for a FanForce parameter so that the value goes from 1-100 from frames 1 to 600.
Can this be done using some sort of snippet?
do you mean like the fit function? You can put an expression on the parameter such as fit($FF, 1, 100, 1, 600)
I guess it should be the other way around from what he describes.
fit($FF, 1, 600, 1, 100)
-J
Edited by jjayakumar - Nov. 5, 2019 23:35:20
jjayakumar
-J
correct, I probably need more sleep.
It happens
Cheers
-J
