linear workflow
2161 5 1-
- mickhah
- 32 posts
- jsmack
- 8177 posts
Houdini is in a linear workflow by default. You don't need to do anything to change to linear light. The viewing space is gamma 2.2 for the render and scene views. Depending on your texture sources, the texture reads can possibly mis-identify the source space, and either double linearize a texture that was already in linear space or not linearize a texture in gamma space that needs linearization.
Its hard to say why an image may differ from a one rendered in maya, it could be a number of different discrepancies. How are you recreating the scene in Houdini?
- mickhah
- 32 posts
- malbrecht
- 806 posts
Moin,
“linear workflow” is probably a misnomer in what you describe … you would have to use the same render engine, the same lighting values (i.e. the same lighting model to begin with), the same settings on the renderer … in order to get the same output.
One thing you may want to check is whether your “color correction” in Mantra's display is set to 2.2 or not (see attached screenshot).
Marc
Marc
Good bye.
Good bye.
- mickhah
- 32 posts
- malbrecht
- 806 posts
mickhah
hello. thank you it is set to 2.2.
… so you do not have a linear workflow there
At least *that* bit was easy to figure out …Marc
Good bye.
Good bye.
