Trying to move a camera according to some coordinate
   2059   3   1
I'm trying to make a camera follow certain coordinates through time. Coordinate I'm able to collectfrom a txt file, organized like this :
POINTS 417 SPEED 25 TIME 16
Frame XV YV ZV XT YT ZT Roll
1 163.80832 307.56781 -265.75311 175.96983 68.3157 -251.33968 23.58062
2 163.80823 307.56772 -265.75305 175.96985 68.3157 -251.33965 23.58044
3 163.80757 307.56699 -265.75275 175.96989 68.31568 -251.33946 23.5787
417 163.80757 307.56699 -265.75275 175.96989 68.31568 -251.33946 23.5787
I'm able to collect every information I need, such as : the number of key frames, speed, time, every coordinates ….
(XV, YV, ZV are the coordinate of my camera, and XT, YT and ZT are the coordinates of a object I'm looking at)
I'm also able to create a camera :
g = hou.node('/obj').createNode('cam')
and to access some of her parameters
eg : tx = g.parm('tx')
The problem I'm dealing with is about the key frames, and how to change coordinates of my camera every time I create a new key frames.
Do you have any ideas ?
Thank you
(Sorry if they are any English mistakes, I'm not fluent!)
This is basically your own file format. So you would need to create some python code that could interpret your .txt into useful information.
Then its only up to interpolate between the values of your .txt via hou.time() or hou.frame().
Good luck!
Manuel Köster - Senior Technical Artist @Remedy Entertainment
https://www.remedygames.com/ [www.remedygames.com]
http://shadesoforange.de/ [shadesoforange.de]
https://twitter.com/ShadesOfOrange_ [twitter.com]
you might try the Table SOP…?
Training Lead
www.sidefx.com
Hello, thanks for responding ( and sorry for the late answer )
@shadesoforange : I already know how to interpret the .txt into useful information !
Do you have any example to use hou.time/hou.frame with a camera node. I've been looking on internet, but could not find any useful stuff / working example
@goldfarb : https://www.sidefx.com/docs/houdini/nodes/sop/tableimport.html [www.sidefx.com]
Are you referring to this ?
