I'm currently working on a Python Script which will render ass files using kick. I managed to get everything working, but as soon as I want to make a mosaic of these renders, the imagemagick is throwing an error: “There are no images found”. I guess this is coming from the python script which execute kick and doesn't have the proper tag.
So I tried to add this:
pdgcmd.reportResultData(“path/to/image” server_addr=“127.0.0.1” result_data_tag=“file/image”) but the python script is always failling.
If I remove this line, the node is correctly executed but I can't use imagemagick downstream
Thanks for the help
Python Script set filetag
2563 2 0-
- Matthew05
- 94 posts
- BrookeA
- 391 posts
Hi there,
The pdgcmd module is for out-of-process jobs. Since you are running the Python script in-process, you can use this Python PDG API method:
Here is the docs page with more information: https://www.sidefx.com/docs/houdini/tops/pdg/WorkItem.html [www.sidefx.com]
work_item.addResultData("/home/images/test.jpg", "file/image", 0)
- Matthew05
- 94 posts
