OK,
Many of you may for one reason or the other opted for a consumer GPU instead of a Quadro.
The following will require about a dozen system restarts almost after every step you make so as to ensure everything is registered within windows properly.
Though virtually nothing in this guide can cause permanent damage to your hardware or software I should state the following:
Before you begin you should know you are responsible for anything that may go wrong with your hardware or software and I am in no way responsible for anything you do while following instructions from this guide.
It is known for a fact that current nVidia forceware drivers don't “play well” with OGL apps like Houdini.
You either get annoying lag when you navigate your viewport, your screen may be garbled or you suffer from refresh issues with any form of interactive part of the UI (example) [3dspark.com]
If you have any card up to and including the 7xxx series all you have to do is obtain RivaTuner 2.0 [guru3d.com] (or higher) as well as the nVidia forceware graphics driver [nvidia.com] suited for your system.
Install the driver for your card but DO NOT DELETE the temp folder (usually x:\NVIDIA\Winxxx\driver.version) as you will need it later.
After the obligatory system restart install RivaTuner (typical installation) and restart again.
Run RivaTuner and click on
And then select
Click on the NVStrap driver Tab
And click Install, click OK and restart your system as prompted.
After a successful restart return to the NVStrap Tab and from the drop-down menu for Graphics adapter identification select “Custom” and click Apply.
A new option box will appear
At this point it won’t hurt your system to try until something works (select a device ID and then restart the system) but here’s a couple I know from experience that work.
“GeForce 7900 GTX” can become a “Quadro FX 4500” with ID 009D
“GeForce 7900 GX2” can become a ”Quadro FX 4500 X2“ with ID 029F
”GeForce 7950 GX2“ can become a ”NVIDIA Quadro FX 5500" with ID 029C
After you select the desired Device ID you need to restart your system as prompted.
Upon a successful system restart right click on My Computer, click on “Properties”, select the “Hardware” Tab and click on Device Manager.
On the Display Adapters section select your graphics card (most probably will have an exclamation mark next to it), right click and select “Update Driver…”
A new Hardware Update Wizard window will come up presenting you with a few options. Select the radio button marked “No, not this time” and click Next.
Next you will be asked what you want the wizard to do, select the radio button marked “Install from a list or specific location (Advanced)” and click Next.
On the next step choose the installation option radio button marked “Don’t search, I will choose the driver to install” and click Next.
You are now prompted to select the device driver you want to install. Uncheck the box marked “Show compatible hardware” and select NVIDIA from the Manufacturer list. On the right hand side you will be presented with a (rather long) list of Models. Scroll through it to locate the Quadro you want your GeForce to pretend to be. Click on Next and follow the prompts to restart your system.
You should now be able to run Houdini without any GPU/display driver related issues.
