I create points in houdini which create particles in Maya. Although the houdini_engine node is connected to the time and only updates it's output when the current frame is set to 1. any other values prevent the node from updating the output.
Can you tell me how to fix this issue? Is this a wanted behaviour and I just need to set a property in the hda output parameters?
Georg
Points from hda are only displayed when at frame 1
4978 9 0-
- msearl001
- 10 posts
- johnmather
- 641 posts
Hi Georg,
I'm unable to reproduced your issue. To test, I created a simple HDA that consisted of a box plugged into a mountain SOP, which was then connected into a scatter SOP with the offsets set to $F/100. Maya loaded this without issue, and the points update over time.
Would you be able to attach an HDA that replicates the issue?
Thanks.
Thanks.
- msearl001
- 10 posts
Okay thanks for your example.
So you example works as well. What I found out:
Only when I add $F and the node gets the clock symbol on it, Maya updates the particles.
If I don't have any $F inside of my nodes, they output is not generated. But I think this should be also updated at least when I click “Sync Asset” (although also changing parameters should update it). If you are working in a scene with a timeline range e.g. 500-700 then you never have the chance to get the points updated.
If you remove your $F from your node and make it non-timeable and plugin a parameter from you hda you will see that in maya the points only get updated when you are at frame 1.
When you combine bothin the Force Total Count parameter you will see that points update when changing the timeline in Maya, but if you change the parameter numpoints on the houdini asset in maya, all points get lost and it will output: “No geometry generated”. Going back to frame one and sync the asset and the points show upagain!
Sorry, I have no permissions in my browser to upload files to the internet
I'm using:
Maya 2018.4.6
Houdini Engine 17.5.293
Best regards,
Georg.
$F * ch("../numpoints")
I'm using:
Maya 2018.4.6
Best regards,
Georg.
Edited by msearl001 - Dec. 8, 2019 19:33:14
- johnmather
- 641 posts
- msearl001
- 10 posts
- msearl001
- 10 posts
- johnmather
- 641 posts
- msearl001
- 10 posts
- johnmather
- 641 posts
- msearl001
- 10 posts
