In the documentation to the custom scheduler, you are saying that scheduler properties should be added to a file called “topscheduler.user.ds”. But what if I have couple of schedulers? How to properly make distinguishable parms. for them?
Multiple schedulers parms. inside one file? Include different files to some central .ds file (similar to SOHO parameters)?
Looks like workflow for override properties is changed between Houdini 17.5 and 18.0. Can you please explain what is changed or provide a link (with this description)?
Ostap
Custom Scheduler: Override Job Properties
2832 4 1-
- Ostap
- 209 posts
- chrisgreb
- 603 posts
As you guessed, it uses the same sort of system as SOHO parameters. So if you have more than one custom scheduler your “topscheduler.user.ds” file should `#include` the .ds files for each one. You can see how this is done in $HFS/houdini/properties/top/topmain.ds
The docs for the override workflow is here: https://www.sidefx.com/docs/houdini/tops/schedulers.html#override [www.sidefx.com]
- Ostap
- 209 posts
- chrisgreb
- 603 posts
The workflow in 17.5 is different in that we don't use the .ds files. You add the scheduler job parms to the custom scheduler node in a ‘Job Parms’ folder (as in 18) - note that the Name of the folder tab must be ‘Job Parms’. But instead of providing a .ds file, the system will automatically copy those parms onto TOP scheduler nodes ‘Scheduler’ tab, when they are created. The user then toggles the overrides to enable them.
HIP files are forwards compatible and mostly backwards compatible. The only caveat is that when you open the 18.0 hip file in 17.5 you will have to enable the override toggle to have them take effect.
http://www.sidefx.com/docs/houdini17.5/tops/custom_scheduler.html#spare [www.sidefx.com]
- Ostap
- 209 posts
