Hi. Does anyone know the correct syntax to set up Alice vision in H18, Houdini Labs? I have made a Json file called Alicevision.json in the packages DIR. I have tried all the variables below but had no luck. Best Mark
Edit: as is always the way. Right after posting the question I worked it out. If anyone else gets stuck. This is how to do it:
“env”:[
“ALICEVISION_PATH” : “C:/Docs/houdini18.0/plugins/Alicevision/AliceVision-2.2.0/”
How to set Alicevision up as a *json file rather than env
2175 0 1-
- Mark Wallman
- 736 posts
