Hi!
I have primitives with string attribute: subset_A, subset_B, subset_C. I would like a detail wrangle to check all the string attribute it found and put them in an array.
My current method would end up with duplicates: .
Is there an easy way to only have one of each in my array? Or do I have to go over each value and compare to all other values found… ?
-Olivier
Gather all the different string names on my primitives
3675 4 1-
- olivierth
- 1184 posts
- tamte
- 9407 posts
this will return array of all unique values of string or int attribute
https://www.sidefx.com/docs/houdini/vex/functions/uniquevals.html [www.sidefx.com]
- olivierth
- 1184 posts
That sounds like a great function. Sadly, I don't have access to it in my Houdini 16. I found a workaround for anybody interested. The trick was to sort my array values before cleaning up the duplicates:
int nprims = nprimitives(0); string curValue; //aka current value used string allValues[]; // simply placing all values in an array for(int i=0; i<nprims; i++) { curValue = prim(0, "subset", i); push(allValues, curValue); } sort(allValues); //a long array containing lots of duplicates but all sorted // cleaning (removing duplicates) string storedValue = allValues[0]; //storing first value string cleanedValues[]; push(cleanedValues, allValues[0]); //I need one value to begin for(int i=0; i<nprims; i++) { curValue = prim(0, "subset", i); if(storedValue != curValue) { push(cleanedValues, curValue); storedValue = curValue; } }
- tamte
- 9407 posts
olivierththen just use nuniqueval() and uniqueval(), I'm pretty sure those are in H16
string attrib = "subset"; int count = nuniqueval(0, "prim", attrib); for (int i=0; i<count; i++){ string value = uniqueval(0, "prim", attrib, i); append(s[]@unique, value); }
again for completness in 17.0 it would just be:
string attrib = "subset"; s[]@unique = uniquevals(0, "prim", attrib);
- olivierth
- 1184 posts
