I am rendering an image from
Houdini Solaris LOPs
using a
USD Render render node
https://www.sidefx.com/docs/houdini/nodes/out/usdrender.html [www.sidefx.com]
In the
Render Settings
https://www.sidefx.com/docs/houdini/nodes/lop/rendersettings.html [www.sidefx.com]
for
RenderMan 23
https://renderman.pixar.com/answers/questions/14544/h18-solaris-lops-renderman-23-statistics-stats-emp.html [renderman.pixar.com]
I have ;
-statistics enabled
-set a foo.stats file path
-set a foo.xml file path
When I render, the result is ;
-a successful rendered exr
-a successful .xml file
-an empty .stats file
Has anyone successfully rendered a RenderMan 23 .stats file from LOPs ?
Any suggestions much appreciated.
Thank you.
