Motion blur is not working. Solver SOP.
   8179   7   2
Hello mighty community!
Problem: After continuous search on the forums and digging into Houdini documentation, I'm still not able to get any motion blur in my renders. Tried Redshift and Mantra.
Assumption: I guess that problem is that Solver SOP doesn't generate velocity attribute. Correct me if I'm wrong about that.
Even when I put “Point Velocities” to Instantaneous Point Velocities on Dop Import SOP inside my Solver SOP. Unfortunately velocity attribute in Geometry Spreadsheet is showing zeros.
Attaching organized HIP file with Redshift and Mantra ROPs to this post.
Thank you in advance for any help!
Edited by yakymoto - March 6, 2020 02:22:00
liquid_lines1.hip (10.0 MB)
Best regards, Stanislav Yakymenko.
Houdini artist based in Berlin, Germany.
yakymoto.com
Solver sop is a bare bones tool, it doesn't do anything by itself. You're on your own for all aspects including generating consistent topology for deformation blur, or proper velocity attribute values for velocity blur.
Thank you @jsmack for your explanation!
1) Got it - Solver SOP concept is operating on previous frame geometry. And initial geometry has no velocity attribute.
Adding random/custom velocity attribute before Solver SOP or calculating velocity with Trail SOP after the Solver SOP unfortunately doesn't give me a correct result (attaching latest HIP file).
Any idea, how can I get this proper velocity attribute?
2) To make constantly growing lines smooth I'm using Resample SOP, which generates more points each frame. So consistent topology for deformation blur is not possible to achieve or I am wrong?
liquid_lines1.hip (10.1 MB)
yakymoto.com
Hello
i managed to get some motion blur in Redshift
as you are moving your line with a curl noise i just plugged this noise value to v
and also as you are raying those line so i calculated and add this translation to v
then on the object tab you have to enable motion blur from v attribute
and also in the render tab..as i think it create a very low velocity value i increased a lot the frame duration
in redshift motion blur tab…but you could also post multiply v attribute as it is “fake” velocity anyway …
one think wich i think doesn't look to cool is that the line are on top of each other , you should fuse and polypath
but that's another story !
i hope it help
Benjamin
Edited by Benjamin Lemoine - March 6, 2020 11:20:19
liquid_lines1.hiplc (11.2 MB)
Thanks a lot Benjamin Lemoine!
Brief overview and multiplying velocity attribute 100 times already gives me a decent motion blur in Redshift, which is awesome!
I will deeply investigate your Rest SOP usage to understand what I was missing.
Cheers!
yakymoto.com
I'm glad you found this usefull
don't worry about the Rest sop , it's just doing v@rest=v@P;
you could do it with a wrangle too
it's just because with the ray sop you're moving your geometry again next to the noise
so you have to add this translation to the allready existing v…so that's why i added
v@v+=v@P-v@rest; …this is just adding current position minus previous one to the v
Benjamin
to get proper velocity
move the Rest SOP before pointvop1 (so right after Prev_Frame) as that sop is modifying P too
and change attribwrangle1 code to
v@v = (v@P-v@rest) / @TimeInc;
since v@v in Houdini should always be in seconds
Edited by tamte - March 8, 2020 18:33:37
Many thanks to everyone for participating and your help, the problem is solved!
yakymoto.com
