How to "combine" prim polylines segments?
   5933   6   0
Hi!
I had non-connected polylines (the exploded view sop split all segments apart). I used a fuse sop to weld all of them together.
Is there a way I can have each fused lines to be a single primitive? I need to do this for a resample sop later.
-Olivier
Use Join SOP
or Poly Path SOP
Thanks for the replies!
I tried using the join sop but no matter what setting I used, I got some weird results…
The poly path did the trick, thanks!
-Olivier
Hi I have a set of lines generated from shortest path i tried to combine them using fuse and polypath to one prim but unfortunately always gives me separate prims is there a way around to get that. Thanks in advance!
Screenshot 2023-11-07 170921.png (452.4 KB)
You can't have single branching primitives.
Thankyou!
