UV Overlapping Problem
   3305   2   1
Hi Everyone
Does anyone know how to dynamically fix any overlapping UVs
Here is the file: Your text to link here… [drive.google.com]
What I have done is merge several meshes/geometries
Each of the meshes already has its own uv applied, some are using UDIM
But when i use the merge node, all uvs end up merging and overlapping each other
I have attached screenshots of what I mean and also the mesh object itself that is having the problem
Thank you very much
Edited by henrythejedi - March 27, 2020 13:26:41
I ran a similar issue thread here, but not exactly like what you're seeing:
https://www.sidefx.com/forum/topic/72404/ [www.sidefx.com]
My solution to something like this would be not to merge before using a Material node on each piece of geometry individually first, so that each of your materials link to a specific UV map and not all of them merged together.
>>Kays
Midphase
Thank you so very much @Midphase
I will follow your thread and try what you suggest there
