Texture paint, then transfer color to points
   4451   4   1
Hi I am pretty new to this, hope you can help me….
I want to dress some crystals on a terrain. I like to “paint” where I think the crystals should appear.
I use “paint” node to distribute scatter, that work as expect.
however, if I changed the terrain mesh or use a different terrain, I lose the “distribution”, all previous painted points are shifted.
1. I wondering what I can do so my painted point/distribution always stick to the same location?
2. Can I paint texture (projected UV map) in Houdini and have color transfer to points? I assume by projecting UV map on the terrain, I can keep changing terrain mesh while maintaining the color/distribution information.
Thanks for helping me. I also attached my working file in this thread….thank you so much
Screenshot at 2020-04-01 12-26-24.png (1.1 MB)
TexturePaint_Points.hip (728.7 KB)
yes, you can have uv attribute and then use Attrib From Map SOP to load colors from texture as a point attribute
or you can use new Attribute Paint in H18, and recache the strokes when you change the topology, depending on mode you don't even need uvs
https://www.sidefx.com/tutorials/attribute-paint-h18-masterclass/ [www.sidefx.com]
Thanks Tomas
Thanks for the tips, Im looking into it.
Can we paint straight on a texture and save the texture from Houdini?
Frank
No, you can only paint attribute values
Technically if you have point per pixel then yes, as it's easy to bring that data to COPs and save an image, but that would not be the most ideal workflow for texture painting I guess
Got it, thanks Tomas!
