Problems with $JOB variables
   3972   4   2
Ok this one is new and I'm not sure why I haven't run into this before. I'm able to set my $JOB variable for the current session of Houdini only, it always defaults back to the location it was launched from next time I open my hip file, so all my file dependencies break.
I noticed if I open the hip file in a text editor there's a set -l JOB and a set -g JOB. The local JOB variable is correct, the -g one sees to be causing problems. Also, I'm not able to edit (change) the JOB path in the Aliases and Variables dialogue. Any clues on what's going on here? Thanks!
AndyW
I´m having the same problem and my file has the “SET -g JOB” overriding the variable.
Have you found a solution?
I´ve found a solution, but still don´t know what has caused the problem.
In the python shell u must set JOB in the environment before opening the hipfile, using:
import os
os.environ = “path/to/project/folder”
and then
hou.allowEnvironmentToOverwriteVariable(“JOB”,True)
And then you open the hip file.
There was a bug 106528 that caused problems when there is both `set -l JOB` and a `set -g JOB` in a .hip file. This could happen when JOB was set without `-g` option, leading two to variables: one local and one global. The issue is fixed in 18.5.450 and 18.0.695, where JOB is always forced to be global, even with `-l` option, to make it consistent with other "global" variables such as HIP, HIPNAME, etc.
It's not working for me JOB replace global,I have two PC one for modeling,When I render To Another machine,must I change JOB to full path using command opchange in tab Textport window $JOB to /media/4545HGHKD5GD/Projects/HoudiniProjects.
