Read a multiparm float as a float array
5145 3 2-
- RodrigoMartin
- 27 posts
Hello, following with the procedural vertical graph i was doing last weeks, I am now trying to do a reference in the side of the graphic that shows the relative high, so you have a reference of how much high is each block.
My aproach was creating a block that scale in the Y axis based of the max high of all the parameters of the vertical graph, the high is defined with a multiparm float, and i tough about using the vex function max() but I don't know if it is possible to create a dynamic array from multiparm block.
Thanks you for reading me.
- tamte
- 9417 posts
you can read them in a for loop
if for example your multiplarm folder is called columns and also I'd advise set first instance index to 0 instead of default 1
int ncol = chi("columns"); float alturas[]; for(int i=0; i<ncol; i++){ string si = itoa(i); float altura = chf("altura" + si); append(alturas, altura); } if (ncol>0){ f@altura_avg = avg(alturas); f@altura_min = min(alturas); f@altura_max = max(alturas); }
- RodrigoMartin
- 27 posts
tamteThanks you very much! I knew loops but never though of using this way, you are the best helping everyone here in the forum! Thanks you!
if for example your multiplarm folder is called columns and also I'd advise set first instance index to 0 instead of default 1int ncol = chi("columns"); float alturas[]; for(int i=0; i<ncol; i++){ string si = itoa(i); float altura = chf("altura" + si); append(alturas, altura); } if (ncol>0){ f@altura_avg = avg(alturas); f@altura_min = min(alturas); f@altura_max = max(alturas); }
- OdFotan
- 192 posts
