Depth Map Render
   3030   2   0
Whats the fastest way to make a simple black n white depth map in Houdini? Can I do it with texture sheets?
You can add an image plane with P.z to a mantra ROP but you will have to normalize the result which is in worldspace.
mikelyndon-sesi
I will investigate! Could I request this be added to the T Sheet in Labs? If so, how would I do that?
