I am trying to model a gear, but am struggling with the most basic problem.
I modeled one tooth and want to distribute it to faces of a tube.
That´s the theory.
Should look something like this:
I took a geometry node, with a tube inside. Drawing a curve for the tooth and copied them to selected points on the tube. It works almost fine, but the teeth are not oriented correctly. So I tried to use the normal of the primitive, to attach the tooth, but all things I tried didn´t bring me to the correct result.
I watched some tutorials but nothing helped. Even this one is not solving my problem:
Forum Post [www.sidefx.com]
Could you guys help me? I am having a hard time, getting into Houdini as an old school MAX user.
thanks…d.
