Q: Mapping individual frames to frame numbers?
   1548   1   1
Somewhat related to this (I tried the attached example file on that thread) but have failed to get this to work.
Basically, I have a FilePattern TOP (point it at any dir with non-frame-numbered images, such as $HFS/houdini/pic/hdri/*.rat) and I want to Mosaic the output.
Mosaic COP takes an image sequence, so somehow I have to get the @pdg_input to return a sequence to feed into the Mosaic COP.
In the linked thread, an Interleave is used, but that won't scale of course since that has a hardcoded number of inputs. Plus even in that case I couldn't get it to load two different frames I was thinking @pdg_input.0 and @pdg_input.1 fed into the Interleave but alas, I just get a single output in the Mosaic.
Any pointers most welcome.
18.0.460 Win 10
Peter B
Edited by pbowmar - May 27, 2020 13:33:23
Peter Bowmar
____________
`pdginput(0, “file/image”, 1)`
if I put that in the File COP and make 1 file cop for each image, then feed into a Sequence COP, it works. Alas, this is clearly not very procedural or scalable
Peter B
Peter Bowmar
____________
