how to get an object to sit on the ground $YMAX not working
   5132   2   2
Hi
So within the stage context how you you go about getting an object to sit on the ground. Adding a transform and typing $YMAX does not work in stage. Im trying to make a lookdev tool, so want any object that comes in to be processed to “sit on the ground” rather than through the ground.
Best
Mark
Here's a snippet of something I was messing with - if you have extentHints authored. Perhap you can bend it to your will? YMMV…
from pxr import UsdGeom, Gf
# resolve your 'prim'
# transform to the centroid of XZ and the floor of Y
xh = prim.GetAttribute("extentsHint").Get()
if xh:
xform = UsdGeom.Xform(prim)
xform.ClearXformOpOrder()
t = xform.AddTranslateOp(opSuffix="center")
dx = (xh[1][0]+xh[0][0])/2
dz = (xh[1][2]+xh[0][2])/2
dy = xh[0][1]
t.Set(Gf.Vec3d(-dx,-dy,-dz))
That said, I think LOPs could use some nice alignment/match-size/etc style tools.
Edited by jason_iversen - June 2, 2020 23:33:48
jason_iversen
Indeed, that match size sop from the a couple releases back has become quite clutch. It would make a fine addition to LOPPERs.
