Color Nodes don't show any color in Unreal.
   4083   1   1
Hi everyone,
For quick Prototyping, I'm using the SideFX Labs Color Gradient node. It works great for normal boxes or other meshes. In Houdini, it also works but when I import the HDA to Unreal the object stays white. The objects where it doesn't work are CopyToPoint Instances with a lot of Cubes. IT also doesn't wor with the normal color mode or Side FX QuickMaterials.
Any idea what I'm doing wrong?
Hi
make shure to store the Color as Vertex-attriute. The Labs Color Gradient stores Cd as Pointattribute, so you need to promote it to Vertex and also have a Vertex Color Node in your UE4-shader. I am not shure about Instances though.
greetings
