Floating point error
   2377   4   0
see attached clip. why does this happen? why it can not be just 0.9, why 0.900000000002? I want to put the channel value to the font sop, so I want it to look readable.
s01.mp4 (109.1 KB)
Left click on your parameter label to alternate between the two display options.
To use floats as text in a Font sop, it's best to format them first to the desired readable precision. Use sprintf() in VEX or format() in python to convert the float to a string before referencing in the font sop's text field.
thanx a lot! that's generally what I wanted to know
but does HScript have such expression?
Edited by nuclear_polygon - Aug. 28, 2020 10:20:29
Well…in the font text parameter field you could use Hscript:
`ftoa(trunc(ch('your_string_parameter_reference'))) + '.' + trunc(frac(ch('your_string_parameter_reference')) * pow(10,change_this_to_number_of_desired_decimal_places))`
