Trouble rendering a sequence in tops
   1909   2   0
I am having trouble rendering out a sequence in tops. I have my wedges set up correctly but when I use open gl to render out the sequence of my wedges, I only get 1 frame and not the full sequence. I don't know why because I have my open Gl settings set to “Render Frame Range”
Where am I going wrong here? Driving me a little mad.
I will attach my scene file if anyone wants to take a look.
pdg_wedge_basic.hipnc (934.3 KB)
The output path on your OpenGL ROP is set to F:/pdg_render/v/w`@wedgeindex`/render.F4.png. That should be $F4, not F4, or each of the output files is going to go to the same place.
That would be it. Thank you
