I'm interested in using this tool, but the node that I get when I lay it down with the latest Labs toolset (591) looks totally different and seems to have much less functionality. Is there a way to get the node shown in the docs?
The version you have there is the newer one (simplified the required fiddling around to get it to optimize) and should work mostly the same.
If however you still want to use the old one, you need to enable the asset bar found under Assets>AssetManager/Configuration. At the bottom of that window you'll see a dropdown for it which you have to set to “Display Menu of All Definitions”. Once you did that, youll see a dropdown at the top of your parm interface where you can select the version you want.
