Hda processor in UE4
3962 5 2-
- TRex92
- 43 posts
When using the hdaprocessor in tops how do you get Unreal to recognize a global variable. Is there a certain var name you should use like in Unity with the HEU_ENVPATH. I know in Unity you can create a env file that is then rocognized in Houdini. What is the process for Unreal in order to be able to use the hdaprocessor node in Unreal so I can point it to the correct directory of the hdas?
- chrisgreb
- 603 posts
- TRex92
- 43 posts
- chrisgreb
- 603 posts
- dpernuit
- 559 posts
You can also specify a custom .env file for use with the UE4 plugin in the plugins settings.
(Under Houdini Engine Initialization, Houdini Environment files)
For the PDG Asset Link, you can set the “Working Directory” param on the scheduler, and use $PDG_DIR on the HDA Processors.
The Working Directory can then be exposed on the HDA, and set directly in Unreal.
- TRex92
- 43 posts
