Is there a way to auto set display flag on clicked node?
   5096   9   3
Hi. Another little thing that I find annoying in Houdini. I often need to select a node and set display flag. That right now is two clicks. Is there any chance that there is a key modifier that allows the display flag to auto set in any node I select?
This combined with a node info panel that would show info of node selected automatically (without middle mouse button click) would be so handy in inspecting scenes and trying to follow what’s happening.
Hold down the display flag key ‘r’ when clicking to move the flag on click.
Doing either of those things on selection would cause unnecessary cooking, since most of the time selecting a node is for accessing the parameters or moving the node around.
Thank you!
jsmack
Houdini already cooks on selection by default.
is there a way to automate this with Python, each time I select a node the display flag is on or tempate flag ?
- David
You can use addEventCallback:
https://www.sidefx.com/docs/houdini/hom/hou/Node.html#addEventCallback [www.sidefx.com]
with hou.nodeEventType.SelectionChanged:
https://www.sidefx.com/docs/houdini/hom/hou/nodeEventType.html [www.sidefx.com]
and:
node.setDisplayFlag(True)
node.setRenderFlag(True)
node.setGenericFlag(hou.nodeFlag.Template, True)
animatrix_
and:
Thanks but where should I put this code to be active when Houdini starts?
- David
animatrix_
jsmack
nope.
animatrix_
and:
Where to put this code?
CURRENT GEAR
Laptop: Alienware 51m (i9900K. 128 gb RAM. RTX 2060. 1 TB SSD)
Desktop: Custom-Build (i9900K. some Radeon card. 128 gb RAM. 1 TB SSD + 2 TB Glyph Drive)
Accessories: 3D Connexion SpaceMouse & CAD mouse | Wacom tablet | iPad | OnePlus 7 Pro
CURRENT SOFTWARE LEARNED
2D Asset: Photoshop | Illustrator | Affinity Design | Procreate | Animate | Toon Boom Harmony
3D Asset: Zbrush | Nomad Sculpt | Substance Painter & Designer | Mixamo | Rokoko
Animation & Rendering: Cinema 4D | Maya | Blender + plugins | Arnold | CyclesX + SheepIt | Eevee
Compositing & Video Production: After Effects + plugins | Nuke | Premiere Pro | Ableton
CURRENTLY LEARNING
Houdini | Fusion | Redshift | Octane | Vray | 3Delight | Renderman
Currently streaming my study sessions at Twitch.tv@Retopo001
WHAT I'M LISTENING TO
Audio read aloud by text-to-speech: articles by the Economist | Compiled Wikipedia branches |
Music: Bach - Complete Collection. NIN - Pretty Hate Machine. Aphex Twin.
Retopo001
animatrix_
and:
You have to turn this into a function and then register it like this (this one is using name changed event):
def name_changed(node, event_type, **kwargs):
    print("The geometry object is now named", node.name())
hou.node("/obj/geo1").addEventCallback((hou.nodeEventType.NameChanged, ), name_changed)
But I would recommend a different way. nodegraphhooks actually offers better methods. For example in some contexts I override RMB on a node to diplay that node, but it's a bit more involved to detect what's under the mouse is a node and if so, check the clicked buttons and/or modifier keys.
