Toggle null visibility in viewport (script?)
   10144   26   5
krueger
This one is cleaned up a little bit, also adding the option to run over every scene view or just the active one. Adding a hotkey for the scene viewer will make it work on whichever scene view your mouse is over too.
def toggleNulls(toggleAllViewers=True):
    import toolutils
    # Check to see if the nulls were toggled already.
    if "nullsVisible" in dir(hou.session) :
        visible = hou.session.nullsVisible
    else :
        visible = True
        hou.session.nullsVisible = visible
    try :
        desktop = hou.ui.curDesktop().name()
        pane = toolutils.activePane(kwargs).name()
        views = hou.hscript("viewls -n")[0].split("\n")
        if visible :
            toggle = "-"
        else :
            toggle = "+"
        # Toggle viewers
        if toggleAllViewers :
            for view in views :
                hou.hscript( "vieweroption -V '%snull' '%s'" % (toggle, view) )
        else :
            # Find the viewer name for hscript.
            for view in views :
                if (desktop in view) and (".%s." % (pane) in view) :
        # Change the stored variable.
        hou.session.nullsVisible = not visible
    except :
        print "No scene view open."
# Toggle current viewer
toggleNulls(toggleAllViewers=False)
# Toggle all viewers
#toggleNulls()
Hey Krueger,
would you be so kind to update your script to Houdini 19? It's not working for me. maybe because of PY3?
Thank you!
Cheers
CYTE
Edited by CYTE - Dec. 7, 2021 12:04:42
This should work:
    import toolutils
    else :
        visible = True
    try :
        if visible :
            toggle = "-"
        else :
            toggle = "+"
        # Toggle viewers
            for view in views :
        else :
            for view in views :
    except :
        print ("No scene view open.")
#toggleNulls()
Thank You, much appreciated!
me and my animation team would love to be able to do this with polygons! can i simply replace the nulls flag with something else to make this work? i am pretty limited in my houdini and python knowledge here..... as far as i can tell it may not be polygons in houdini but "characters" ...so sorry for the dumb question
Edited by pbinga - Jan. 20, 2025 15:57:24
pbinga
Hey, can you explain more what you're trying to toggle? It's been a few years, but this is using the hscript command vieweroption so these are the options:
-V ‹visibilitystring›
Set object level visibility by supplying a space separated string of tokens. Each token takes the form '+‹type›' or '-‹type›' where type is one of: *, geo, cam, light, muscle, bone, null, blend, other, or popguide.
https://www.sidefx.com/docs/houdini/commands/vieweroption.html [www.sidefx.com]
were using the apex animate stage in houdini 20.5 and wanting to be able to globally toggle the char vis of all characters on and off with a hotkey rather than per selection set.
I haven't used apex before, but you can try using the script above but just change the 2 lines that actually specify the "null" to use "geo". So these 2 lines:
would become:
hou.hscript( "vieweroption -V '%sgeo' '%s'" % (toggle, view) )
