Vertex Wrangle ad-hoc group doesn't work?
   2759   4   0
I can't make the ad-hoc group @attribute=value in the Group parameter of a Vertex Wrangle work. But I can in a Point Wrangle. Is this a known issue? Am I missing something or it's RFE time?
Edited by probiner - Dec. 20, 2020 09:39:21
PRB_RFE_AdhocGroup_VertexWrangle.hipnc (89.0 KB)
Group type "guess from group" only works for explicit groups, or it assumes a point group for ad-hoc groups on wrangles.
Explicitly select 'vertex group' and it should work.
jsmack
Appreciate the suggestion, @jsmack, helps to create a better report. Unfortunately setting the group to be explicitly of Vertices doesn't work as seen in the image. @foo is not even created.
RFE filed.
Edited by probiner - Dec. 21, 2020 11:10:36
on top of what jsmack said...
you're maybe missing an equal sign, in your Group param'? :
it should be @bar==1, not @bar=1
Edited by Herve - Dec. 23, 2020 01:40:54
Herve
The syntax for @atribute=value is with a single equal sign:
I did try == just to check and all the outputs from points, prims, vertices are the same.
Cheers
Edited by probiner - Dec. 26, 2020 07:30:24
