I like to export the "details" of every frame of one of my scene objects to .json files (or a single file?)
The detail spreadsheet changes every frame.
I'm not sure if there is a SOP for this - I was unable to get anywhere close with python. Any guidance is appreciated!
Export details to JSON files
4479 4 1-
- monomind
- 22 posts
- jsmack
- 8377 posts
The houdini geometry format is json. You could change the extension from bgeo to json on the output of a geometry rop to write out the geometry as json text. Of course this will contain the entire detail as a houdini data structure. For more control over what data is recorded and in what structure, a custom python based rop may be needed. Alternatively use python to post process the json output of a geometry rop.
- monomind
- 22 posts
- jsmack
- 8377 posts
- monomind
- 22 posts
