How to know camera Lens from camera in stageGraph ?
   2535   2   0
Hi !
Quick question about imported cameras from other software that appear in camera's stage graph, is there a way to figure out the focal length ? maybe a way to extract it in VEX or python ?
Cheers
if you look at the SG Details view for your camera primitive you should see focalLength attribute
let's assume the camera path is "/cameras/camera1, then you can access it in Attribute Wrangle LOP using:
float focal = usd_attrib(0, "/cameras/camera1", "focalLength");
or if you are running the wrangle directly on "/cameras/camera1" then you can also just bind it using @:
float focal = f@focalLength;
Exactly what I needed thanks so much Thomas !
