New to Hscript but I have been running a simple script which crashes houdini its simply
echo hello
set i = 0
while ( $i < 10 )
set i = `$i+1`
set j = 0
while( $j < 3)
#echo `vertex(“/obj/gerrycurl/geo1/grid1”,$i,0,“P”,$j)`
set j = `$j+1`
echo $j
end
echo $i
end
I can find a workaround without the second while loop but surely hscript can handle a loop within a loop?!
Can you have a loop within a loop in hscript?
6628 7 2-
- ger
- 6 posts
- Simon
- 2199 posts
There's a much easier way to do this, if all you want is the vertex positions,
1. add an attributecreate sop#
2. set it to vertex type - 3 floats
3. In the value field type $TX $TY and $TZ
4. Open a spreadsheet - RMB and look at the vertex attributes
hope that helps
As to your script it's weird i tried this
set i =0
while ($i < 3)
set j = 0
while ($j < 3)
echo $i $j
set j = `$j + 1`
end
set i = `$i + 1`
end
And it worked fine
I think you are missing a space in the second while loop before the open bracket.
But it shouldn't freeze houdini, I'll post a bug report for you.
hope that helps
set i =0
while ($i < 3)
set j = 0
while ($j < 3)
echo $i $j
set j = `$j + 1`
end
set i = `$i + 1`
end
And it worked fine
- ger
- 6 posts
Oh it must have been a space or something because that is working fine. As for the spreadsheet idea, I need a script to be able to read the positions of the vertices.
Anyway thanks.
Anyway thanks.
www.gerardkeating.com
- edward
- 8166 posts
- Simon
- 2199 posts
- ger
- 6 posts
I'm actually doing a furinterpolation system using renderman procedural runprogram. To start of I create a geo node with a rib procedural for every face on a polygonal model passing in the vertex positions for the corners of the polygonal primitive and interpolating at render time using my own program. Needs alot more work like making the paths realtive but here's the script so far. And yes I know the new houdini will have a fur node.
opcd /obj/gerrycurl/
echo -n “Vertex Listing”
set funrintetropname = au_fur_inter_proc
oprm -f $funrintetropname
set netname=furinternet
nbrm -f $netname
nbadd $netname
set vertexPos=vertexPos
opcf
foreach i (`primlist(“/obj/gerrycurl/geo1”,“all_faces”)`) #1
set v = 0 #each primitive is a curve
while ($v < 3) #2
set primNormal$v=`prim(“/obj/gerrycurl/geo1/model”,$i,“N”,$v)`
set j = 0 #for x,y,z
while ($j < 3) #3
set $vertexPos$v$j = `vertex(“/obj/gerrycurl/geo1/model”, $i,$v,“P”, $j)`
echo `vertex(“/obj/gerrycurl/geo1/model”, $i,$v,“P”, $j)`
echo ${vertexPos$v$j}
echo *
set j = `$j + 1`
end #3
echo
set v = `$v + 1`
end #2
opadd -n geo $funrintetropname$i
oplocate -x 0 -y $i $funrintetropname$i
opparm $funrintetropname$i rishader ( ‘`chs(“../rishader2”)`’ ) detail ( procbound ) detail_ribproc ( '“RunProgram” ')
nbop $netname add $funrintetropname$i
echo
echo *********
set i = `$i + 1`
end #1
nbrm -f $netname
nbadd $netname
opcf
while ($v < 3) #2
while ($j < 3) #3
echo *
set j = `$j + 1`
end #3
echo
set v = `$v + 1`
end #2
echo
echo *********
set i = `$i + 1`
end #1
- Simon
- 2199 posts
Well in fact the existing Houdini has one too.
Does pretty much exactly what you want I think.
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=6069&highlight=fur+otl [sidefx.com]
- ger
- 6 posts
ops:
