Hello, I need to generate a brick pattern on a mesh. Could someone help me get started with the Brocker node? I tried many things but I don't find it in the TAB menu...
https://www.sidefx.com/docs/houdini/nodes/vop/bricker.html [www.sidefx.com]
Gz
Bricker 2.0 VOP node: how to use?
3987 6 1-
- Grendizer
- 392 posts
- joenyc
- 74 posts
- Grendizer
- 392 posts
- jsmack
- 8177 posts
Grendizer
Gz
bricker is a VOP, used in materials. Are you trying to make a procedural texture?
- goose7
- 80 posts
jsmackGrendizer
Gz
Well, I want to use bricker in material.
I want to use bricker or boxes like how we did that in 3DSMAX/VRAY.
We drag a procedual tile texture in the material editor and hook it with a standard shader. Then our ground shows a real-life brick tiling pattern.
But in Houdini, the boxes VOP node does not have a vec3/color output, so I'm confuse on how to do that. There is no demo or description in the document.
Edited by goose7 - Nov. 11, 2022 13:19:32
- jsmack
- 8177 posts
goose7
it doesn't output a color, it outputs a uv coordinate, for connecting to a texture or noise or other pattern. Outputting a color wouldn't be very useful.
- Grendizer
- 392 posts
