Compile a vex library
4201
6
4
DonRomano
April 14, 2021 8:44 a.m.
Hey, I've been struggling a bit on this and didn't found how to do it properly. I've made a few .vfl files with functions definitions, and I'd like to compile them and then call them in attribute wrangles (to gain some performance and avoid jit compilation each time the code is run).
The way I tested was :
test.vfl :
#ifndef TEST
#define TEST
cvex print (string message ="" )
printf (message );
#endif
vcc test.vfl -> outputs a print.vex file
I define HOUDINI_VEX_PATH to include the directory where print.vex is
in Houdini, in an attr wrangle :
#include "print.vex"
print ("test message" );
And I have a warning : "Errors or warnings encountered during VEX compile:
/obj/geo1/pointwrangle1/attribvop1: No context function defined.. "
Edited by DonRomano - April 14, 2021 09:09:29
jsmack
April 19, 2021 4:12 p.m.
rafal Normally (in surface or displacement context) you would use the `import` keywordimport print ;
print ("message" , "test message" );
however, I don't think import is supported in the `cvex` context, so you can't do that.https://www.sidefx.com/docs/houdini/vex/shadercalls.html [www.sidefx.com ]The example in that help page is a cvex shader, is it really not supported?
DonRomano
April 20, 2021 11:24 a.m.
however, I don't think import is supported in the `cvex` context, so you can't do that.https://www.sidefx.com/docs/houdini/vex/shadercalls.html [www.sidefx.com ]Thank's for the answer !
I tried with the import keyword, and it recognizes the function but that still does not work.
import print ;
This returns an error :
No matching function for print(string). Candidates are: void print(; ... ) When I don't pass any argument to the function, calling it like this :
I don't get any error but the function does nothing, thought I changed it to this (to see if I could get something out of it)
#ifndef test
#define test
printf ("test message" );
addpoint (geoself (), { 0 ,0 ,0 } );
#endif
Maybe what I'm trying to do is not supported and I already have the maximum speed I can get from wrangles, and then I'll work with the hdk to do what I want to do. I have another question, because I'm not sure : are wrangles recompiled each time they are cooked (in a for loop for example, though I believe they cache the compiled code somewhere and load it each time) ?
Edited by DonRomano - April 20, 2021 11:55:47
rafal
April 20, 2021 11:51 a.m.
Ah, yes it is supported. I swear there was some CVEX limitation in the past. I must have forgotten it got removed at some point. Probably when allowing to save cached code on CVEX HDAs. Anyway, @DonRomano, you can use imports to reuse CVEX code.
rafal
April 20, 2021 12:36 p.m.
DonRomano I don't get any error but the function does nothing,Hmm. It should work. I have this test function in foobar.vfl
cvex foobar (export vector out = { 0 ,0 ,0 } )
out .y = 0.5 ;
and this code in the Attrib Wrangle SOP (connected to an output of a Grid SOP):
import foobar ;
foobar ("out" , v@P );
and the grid is "lifted" in the viewport to y=0.5 plane.
DonRomano
April 22, 2021 11:23 a.m.
rafal DonRomano I don't get any error but the function does nothing, Hmm. It should work. I have this test function in foobar.vflcvex foobar (export vector out = { 0 ,0 ,0 } )
out .y = 0.5 ;
and this code in the Attrib Wrangle SOP (connected to an output of a Grid SOP):import foobar ;
and the grid is "lifted" in the viewport to y=0.5 plane.Thank you, got it now ! I wasn't sure about the syntax !
