mix and add node
2429
1
0
Hi, I am doing a composite with differents map, I have an issue...
- This is the skin with a mask in the mix node:
- The cloth with the same process:
- And the final is an add node, here I have not the good result...
Do you have an idea?
Thank you for your help,
Sle
Edited by Sebastien Levieux - July 12, 2021 14:52:31
- CYTE
- 783 posts
Hey Sébastien,
have you tried to clamp the values before the add. maybe you have values below zero.
Cheers
CYTE
