multiple karma rendering in sequence?
   3996   4   1
Hello gang, I have multiple Karma nodes that I'd like to render. Previously I'd merge Mantra nodes and press the render button on the merge node but this isn't the same behaviour here. How would I go about rendering multiple karma nodes in sequence?
Thanks.
the fetch rop should work with the usdrender nodes inside the karma ops. Fetch rops can be chained together much like mantra rops or used with other flow control ops.
Alternatively, there's TOPs which has similar dependency abilities, but is less straightforward to put into practice.
jsmack
Great thanks so much jsmack, I applied this and it worked.
jsmack
Hi how exactly chain fetch nodes in stage context?
Not infront of computer but something like this should work.
Make a ropnet and make fetch nodes that are pointing to the karma usdrender rop.
