Curve Point Fuse issues
   2556   2   0
hellow bad asses. i cannot seem to achieve what i feel like should be solved with a simple fuse. i set up a Carve to islate sections of a curve but i can't seem to close the edges of my result. it seems to split where it shouldnt.
Edited by organic_syndicate - Oct. 16, 2021 01:06:58
A fuse sounds like it should work, but it doesn't actually connect primitives such as curves. It only makes vertices from nearby points share a single point, with the extra points removed. The primitives composed of those vertices are unchanged.
There is a special tool for connecting curve segments into a single curve, polypath. It finds nearby curves and joins them into a single curve where possible.
OMG THANK YOU. that worked THANK YOU THANK YOU
