cops file path controled by vex, fails to show image SOLVED
2243 5 0-
- olivierth
- 1177 posts
Hi!
I'm making a setup to read a different image at each frame. In a detail wrangle, I setup the image path like so:
frame 0 : "...folderA/green_texture.tif"
frame 1 : "...folderB/blue_texture.tif"
in the cops' file path, I used:
`details(../../texture_export_path/, "albedo")`
When I middle click on "File", I can see the path makes sens at each frame. Yet, only the frame 0 shows something in the composite view. At frame 1, I get an "X" image instead of the texture. Its odd because the path displayed at frame 1 looks good. I even copy/pasted the path to another file node and it works.
Anything I'm missing?
Edited by olivierth - Oct. 21, 2021 11:11:46
- tamte
- 9379 posts
- olivierth
- 1177 posts
I tried adding the " op: " but it changes nothing. Also, even before I added that, the path was getting picked up from the wrangle as it should. I can tell because when I middle clicked on "File" to show the path, it looks just right. Not only that but when I do copy this path directly into another file node, I can see the image.
I would also like to better understand what the "X" means in the composite viewer. When I create a file node and type random letters in the file path, I get an error on the node and a black screen in the viewer. But with my path generated from the wrangle, I don't get any path error and I get that "X" in the viewer...
Edited by olivierth - Oct. 21, 2021 09:47:25
- olivierth
- 1177 posts
- olivierth
- 1177 posts
- olivierth
- 1177 posts
